i understand the engine will go right in.The question i have will the clutch and pressure plate from the 5 ton mate right up to the deuce transmission? anything else i should know if i do this swap. how does the lds preform in a deuce?
No, the 5ton MF will not go right in, for many reasons....
....but it can easily be converted using some 2.5ton MF-parts, to perfectly fit in a Deuce. That is: get the oil pick-up and cross-over tubes for the oil pump from any 2.5ton model MF and swap them out, then flip oil pan and dipstick position, use the 2.5ton bell-housing + adapter ring, a 2.5ton flywheel + clutch and disc, and the spacer for the starter motor. Any model MF turbo will work fine.
Do this simple conversion (like the military did!); it is well worth your time and the difference in performance is very noticeable!
(We have discussed conversion details many times in the past, just can't find some old posts this time...
G.
