Dumb question
l1a1man
idaho
M1009. Got in today and smelled radiator fluid. You guessed it, heater core shot. Can't replace it until tomorrow night, is it safe to drive 140 miles just don't use the heat?
NDT
7,510
Camp Wood/LC, TX
Pinch the heater hoses shut with vice-grips if things get worse while driving. Not using the heat won't releve the pressure on the leak, so at least stay warm.
Westech
CPL
6,104
212
cow farts, Wisconsin
turning the heater to off will do NOTHING to slow or stop the loss of fluid. like what was stated above.. pinch off the hoses.... better yet you can get a adapter to connect the hoses together. 1/2 to 3/4 or 5/8 I cant remember but most every auto parts store will have this.. look in the thermostat and radiator cap place.
91W350
60
Salina, Kansas
Frequently, you can sneak by leaving the radiator cap loose so the system cannot build pressure. This time of year it works better than in the summer when you are fighting heat. You may lose a little coolant, but it will be minimal.
Westech has the best solution though, use the adapter, remove the hoses from the core and just hook them together. Glen
4bogginchevys
rathdrum idaho
5/8-3/4...great idea.:-D
