m1garand_man
- 0
- 0
- Ft Wainwright / AK
I have an 86 m1009 w/ 96k on the odometer. I've had it since 87k and made the mistake of running diesel clean through it a few times to see if I could clean it out and get it to do 20mpg . its progressivly gone from getting 18.5mpg freeway to 15.3mpg. whats going on? I changed the mechanical fuel lift pump because it started leaking. I changed out all the rubber lines for the same reason. it has a new fuel and air filter and new injectors. what can I do to bring it back up? will I have to change the injection pump? the scribe mark on the pump is lined up with the mark on the timing housing so the timing should be good. I dont want to change it and not have any improvement. I changed the injectors because it was in the mileage where its reccomended to do and it didnt help with the economy. please help ![So lost :lost: :lost:](https://www.steelsoldiers.com/images/smilies/iamlost.gif)
