pinbill
- 0
- 0
- denver, co
Hello-
Just put a temp gauge in my 85 M1009 using the block off plate on the manifold. The temp never gets past 170 is this too low?
I would like to get it a bit higher for use with WVO. What is the OE temp rating for the thermostat?
To get the sender plate in place I had to remove a circular device that looks similar to the CDR valve. It was in between the two manifolds, right under the resistor, in the back of the engine. It had some rubber lines that connected to the injection pump, they were shot so I replaced them with fuel line. What is this thing and what does it do? Is fuel line OK?
Any help would be appreciated,
Thanks,
Bill
Thanks,
Bill
