Thanks to Google, I found this long-dead thread that has exactly the information I needed. Sorry to revive such a relic, but for the benefit of other newbie Googlers who stumble across this, I'd like to add just a bit of additional info to the PTO speed diagram that I had to spend some time looking up. My colorblind eyes didn't initially pick up on the color coding, but closer inspection shows that 2 different transmissions are covered in a single diagram. The PTO will spin at different speeds depending on which transmission you have. The top numbers relate to the much less commonly found Spicer 3052. The bottom numbers relate to the more commonly found Spicer 3053A, which is easily identified by the goofy shift pattern having 4 & 5 in the "wrong" place and is almost universally found behind the multi fuel engines. The rear output shaft may or may not exist on your transmission PTO. If it's there, it is a great way to spin a hydraulic pump. Unlike the front output shaft that can be shifted, it runs only one direction and speed. What is not shown here (it's in the TM) is that the rear shaft has its own engagement fork that allows it to operate independent of the front output shaft.
It may be worth mentioning here that a completely separate PTO can be mounted on the transfer case which might be an option for someone looking to add a hydraulic pump. It would require shifting the transfer case to neutral and placing the transmission in the gear of your choice to get stationary hydraulic pressure.
Do you mean for the transmission PTO? Here it is...
(Hope my diagram is understandable to everyone...)
Gerhard
