dcwilkie
- 2
- 0
- Huntsville, AL
After the ice storm cave-in on Tinkerbell, I decided to rebuild my bows. The uprights are no problem. The curved bows seemed daunting until I remembered laminating some curved pieces for my Bellanca fuel tank covers.
All you need is some really good waterproof glue like Elmer's woodworking glue or slow-cure epoxy, some thin strips of plywood (1/16 inch is best)
1)Cut five equal strips the same length as the bow or whatever it takes to make the correct thickness.
2) Wrap a good bow with wax paper and tape in place
3) Using the good bow as a form, lay up the strips on top of each other and clamp in place onto the form. Use LOTS of those spring clamps you can get at Home Depot, Lowe's or wherever. Maybe use broken pieces of the old bow to spread out the clamping pressure?
4) When it looks good and alot of the glue comes squirting out, leave it alone and let it dry.
5) Once dry, sand it down to remove excess glue, round the edges and drill the bolt holes. Paint/ seal. Bolt together. Install.
I think this would certainly be an improvement over the stock wood bows. Maybe not a good a fiberglass, but I bet they won't be as heavy.
If you use one layer of Mahogany plywood on the bottom, they would be right pretty too!
p.s. Anyone have two corner pieces they want to part with?
