I just had my starter rebuilt and when I went to but it back on the bracket on the back doesn't line up now????? would I be ok to drill another hole in the bracket so it'll fit or is the a bad idea,and another thing the spacer that goes between the starter and the block it wont fit either?I put one bolt thru one hole and just moved it as close to the other bolt as possible so it would at least do its job and space, i'm i screwed ??
