Guy's hi I'm new guy jumping in here with related questions instead of cluttering things up with a new thread so hope somebody help me here instead. Thank you.
My question is this: I see where they had a model of converter would that work to effectively "adapt" the 400 hrtz units for whole house or building stand by here in Florida for hurricane after support I can see the economy in these that sell cheap becuause they are a white elephant and any airport that needs one is buying a new one not monkeying around with something from 1986 like mine is it's a A/M32A-86A and I'm in the process of researching the feasibility of adapting or converting it from 400 to 60 because if this can be solved once and affordably then it becomes a key way to cheaper power or stand alone A/C. If I am wrong ok, I am in the research process but just because no one had done it before don't let that stop us because that's where the money can be found is in doing what noone else can/wants to do but it might not be so bulky of an adapter or the one the military used the model "A/M24M-5 Static Frequency Converter" (complete copy and paste of this link below):
http://navybmr.com/study material/14014a/14014A_ch10.pdf
If you have time to check out the link it's on page 9 and it's big as **** but if you also bought these adapters (cheap as ****) could you use the most expensive compoenents and jettison the stuff that auto senses and is military redudant and non essential because you would have to in order for the size to be manageable to home owners don't have the real estate the airports do for this.
The static frequency converter (SFC) (Figure 10-14) is a 4-wheeled, not selfpropelled vehicle and must be towed or moved manually. It is equipped with tiedown rings, pneumatic tires, a mechanical hand brake, and a tow bar for towing and steering. It is designed for flight deck conditions as well as land-based theaters.The SFC consists of two major assemblies: the trailer assembly and the converter assembly. Input power is provided from shipboard and shore-based receptacles that supply an external power source of 440/220-VAC, 3-phase, 60/50-Hz, ungrounded. The SFC converter assembly automatically senses either 440-VAC or 220-VAC input. The input phase rotation is insensitive and will operate normally when rotation is in either direction. The SFC converts the input power and provides converted power via four 30-foot cables providing 115-VAC, 3-phase, 400-Hz, 270-VDC, and 28-VDC providing electrical power to aircraft/equipment aboard ship or shore.
