panzerjunky
- 1
- 0
- san diego ca
Hey anyone can the gauges on an M35 be taken apart and cleaned without damage ?
Thanks Jerry
Thanks Jerry
gringeltaube, your posts are most informative and give me the impression you have spent many years with these trucks. Thank you for sharing your knowledge with us and for posting photos of your work.Yes, they can be opened, lens polished and most can be restored to like-new condition!
They can be, but the real question is "Is it worth it?" with replacements being so cheap...
No..only for the last 15years....................... you have spent many years with these trucks. ...............................
Agreed Bjorn, but not as difficult to do as one would suppose. Actually it takes more patience to start - carefully pry up - open the rim evenly to avoid cracking; not even 360º all around, just enough for the parts to come apart. The ring holding lens and gasket to the body is made of soft, relatively malleable brass. It will go nicely back into place so that one could barely notice it had been forced open.Crimping that edge back on would be the biggest roadblock for most of us, IMHO.
![1358997306911[1].jpg 1358997306911[1].jpg](https://www.steelsoldiers.com/data/attachments/279/279873-9ef95b81d31381810acbbdbbc44c487b.jpg)
![CAM00016[1].jpg CAM00016[1].jpg](https://www.steelsoldiers.com/data/attachments/279/279874-61c3bf393fa3a67b7e41c971569fc31e.jpg)
![CAM00017[1].jpg CAM00017[1].jpg](https://www.steelsoldiers.com/data/attachments/279/279875-8d4b98ac520c0b54974544afdcfb5469.jpg)
![CAM00018[1].jpg CAM00018[1].jpg](https://www.steelsoldiers.com/data/attachments/279/279876-c683f76c21f886248af78f83831d506c.jpg)
![CAM00022[1].jpg CAM00022[1].jpg](https://www.steelsoldiers.com/data/attachments/279/279878-46f489c803307f47f4c59ba836346bf7.jpg)
You mean...there are OTHER tools to work on a Deuce????Obviously good results can't be achieved just with a hammer and screwdriver
To evenly press it back to original shape I use exact fitting bearing cups, eventually turned/chamfered accordingly. Will try to find what size/ part# it was for the speedo........................................When I find out what I'm going to use to re-crimp the ring I'll post pics.......
Sometimes YES, see above...You mean...there are OTHER tools to work on a Deuce????![]()
