I purchased a 10" centrifuge from Tim at Wolverine Technologies prior to Christmas in order to take advantage of the $100.00 discount he was offering at the time. My observations are as follows:
* Tim answered all of my questions prior to the purchase in a timely manner.
* It arrived in the time-frame he said it would and was packaged well.
* The valve on the lid is not like the ball valve pictured on the web site. This is NOT a problem at all that I can see. It came with a gas valve rather than the ball valve. It shouldn't make any difference which type is on there.
* The little On/Off switch on the unit was broken when I unpacked it and I couldn't find it in the packaging (I could have missed it as it was shredded paper packaging). I emailed Tim about replacing it and sent a picture of the broken part. It took some time, but he did send me a new switch plate at no charge (Thanks, Tim!). I wasn't in a rush for the new part and he had family obligations, which is understandable.
* The bolt that holds the bowl onto the motor shaft was on finger-tight. I would suggest that no matter what kind of centrifuge you get, make sure everything is tight before you start it or use it EACH TIME. That's just a safety thing and may be unnecessary after you know it's on tight to begin with. I plan on putting a lock washer on the bolt or one of those nylon lock nuts unless Tim or anyone advises against it for reasons I am yet unaware of.
* The aluminum bowl is very nice with only a small portion inside (maybe 2"x4") where the anodizing didn't cover all the way.
* I have plugged the unit in and fired it up. It runs smoothly and it's quiet.
* Over-all, the fuge is well built and Tim has been great to deal with. I'm really glad I saved a hundred bucks to boot!
I have not used this cetrifuge yet since I have not completed my set-up and lack some things. I have yet to get a barrel band heater and have looked at several sources. I've decided to buy one from PA Biodisel since their price is comperable to others on the market and the one's PA Biodiesel has are MADE IN AMERICA! (Ohio to be exact) The other barrel band heaters I've found are made in Communist China.
PA Biodiesel also has bulhead fittings, which I will get from them as well. I have my barrels and my brother in law will be helping me fabricate some sort of stand that safely mounts two WMO drums up high enough as everything will be gravity fed. The only pumping will be with a hand-cranked fuel pump with a NAPA in-line fuel filter attached to transfer the cleaned oil to my Deuce or fuel cans.
I am going to make a drill driven pump to get the WMO from my sources to the barrels in my truck to my WMO drums in my "plant". I found plans to make one from a '77 Chevel small block oil pump that's about $20.00 from NAPA.
When I have it up and running, I will post more on the Wolverine Tech. fuge and how it performs. I'll also post pics of it when I get my camera figured out again (it hasn't let me post pics on SS the last few times I tried and I've posted them here before with the same camera). It will likely be spring before I can add more to this thread due to a remodeling project at home that always takes ten times longer and 100 times more money than you planned on.
To sum it up- I am happy with Tim's service and his product. His price was considerably less than Simple Centrifuge's unit, which may be more refined in certain aspects, but I'm not rich and just want something that works. (I got a John Deere green fuge, by the way.) Hope this helps some for those interested in purchasing a centrifuge. More later...![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
EDIT: I forgot to mention that I will be sending out some samples of the cleaned WMO to CAT for analysis to see just how clean the oil gets.
