CUCV Build... Here We Go Again...
jakwi
Colorado Springs
man as old as this thread is I figured I'd get to read through the whole build. I'm really curious how it ended up. I'd love to know what donor vehicle the seats came from.
Matt65
Alabama
Yeah, I hope we get an update soon as well. Amazing build.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
It has since been through another transition. The engine was pulled, freshened up and new heads installed. The 700R4 was scrapped in favor of the 4L80E and an all digital dash was installed. Only a few more bugs for Mike to work out!
1986Blazerk5
Brighton,MI
Man.... the abuse... Ok so your not Office Space fans!!! (that movie is one of the greatest of all times!)
Here is a few more pics! Inside sandblasted, epoxy primer and bedliner sprayed...
Going to pick up the paint now... Should see some color by monday in various places!
what kind of bedliner did you use?
Recovry4x4
LLM/Member 785
1,827
GA Mountains
The new 4L80E fried itself to a crackly crunch. Other than that, it's pretty much done. The tranny was new but a faulty and clogged aux cooler cost the tranny and all the expensive components it's life. Again the truck has been placed on the back burner in hopes that Mr Murphy will soon die a painful death.
1,540
62
Riyadh, Saudi Arabia
Did Mike not flush the cooler before installing the tranny? I just had my trucks tranny rebuilt and put on a new trans cooler and bypassed the factory cooler. If I ever have to have it rebuilt again I will just replace the cooler it was only 60 bucks alot less then the cost of a rebuild.
1986Blazerk5
Brighton,MI
Where did you puy the cooler? I want to add one as well
Recovry4x4
LLM/Member 785
1,827
GA Mountains
It was a new cooler, plugged from the factory. Thats what sucks about the whole deal. Guess we need flowmeters on everything.
1,540
62
I got it from autozone. Im not sure what size would be needed for a CUCV to provide proper transmission cooling. I put this one on my 2002 Dodge Dakota Compressor Works/Transmission Oil Cooler | Transmission Oil Cooler | AutoZone.com
If you wanna go to the trouble and expense you can get a tranny cooler with shroud and fan from B&M. I believe you can also add a electronic thermostat to trip the fan off and on and run a temp gauge.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
It got really complicated after that. I stood down and am now on deck if Mike needs anything.
