battery overcharge?
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
hi guys i need help one of my old batterys got over charged and started to leak water ok so i replaced em both with nre optima red tops batterys and now my top most battery cloest to the firewall is leaking water now WTH?? what could be going wrong?? oh fyi i blew a raditor hose a few weeks ago right by the altanator could water have messed everything up?? what should i do?? the volt metter is in the red now
319
Lieutenant
57
Michigan
Sounds like you're cooking the battery. First check all of your connections to be sure they're clean and tight. Check the voltage at each battery, and check your output voltage at each alternator. Should be around 14.5 volts. If it's more than that you may have a bad voltage regulator. Have the offending alternator rebuilt or do it yourself if you are so inclined. If you have it rebuilt be sure to let the rebuilder know that it has an isolated ground.
MuleMac01
158
Las Vegas Nevada
thanks i prob know what alternator it is the one problem.. the alternator near the upper radatior hose that blew everything was working fine befor 5 gallons of coolent washed everything out hehehehe
is this the the right alternator? M1008, M1009, M1028 CUCV ALTERNATOR 12V 1105500 OE 100A : eBay Motors (item 110511978442 end time Apr-01-10 18:56:07 PDT)
hovenga67
Evansdale/IA
The passenger side alternator charges the back battery by the firewall. The other one does the front battery. That alternator looks like it should work fine. But is there anyone local to you that rebuild alternators. Usually that is cheaper.
Brent
SmokeyDod
Easley, SC
Unless you have money to burn, I would have it repaired at a reliable alternator shop. I have had 6-10 of these repaired an it has never been over $35.00 and usually it is the regulator. I suggest, if you do it this way, I would take the other one in with bad one & just ask them to check it.
I would tell them that both are "Isolated" ground to use on a 24V setup on military truck JUST to be on safe side as they should be able to tell just by looking at back of alternator.
