Fluid quanities
REDWOLF
Risingsun Maryland
Does anyone know how much antifreez, motor oil and trans fluid goes in a M1009 with a 6.2 :?: I will be changing my lift pump and radiator out this friday and hopfuly changing the oil if i get her to run again. She has a bad lift pump?
Warthog
244
OKC, OK
From the Wiki post or the Resources page, download the
Lube Order LO 9-2320-289-12.
It covers all the fluids, quanities, grease points, etc
CUCV85
central/ny
:ditto: Lube Order
Engine oil in my CUCV with Normal Fram PH5
is 8 quarts TOTAL
for some reason.
(I am NOT using a 1 quart Filter)
