hmmwv starter on a m1009
dmc-4359
Chapin, SC
It looks like it will interact with the flywheel without any issue, but the solenoid seems to be almost 90 degrees off from where it would be on a Blazer. Might run into clearance issues with your frame rail. Maybe even the exhaust but my exhaust is not stock and it's the only one I've ever seen up close. Should be readily apparent when you set it in place either way.
beanman1
in the south
i got to looking at it today tried to test fit there is no way that 40 pound mass is going between the frame rail and the block but thats alright warthog bought it from me so i dont have it no more
