Westech
CPL
- 6,104
- 207
- 63
- cow farts, Wisconsin
ok noobs.. I am wrong. sorry. CT did not do testing on air temp movements in the intake manifold a bunch of years ago.....
All I did was to verify that the coolant surrounding the intake manifold did indeed cool the air from the intake manifold adapter (turbo outlet).ok noobs.. I am wrong. sorry. CT did not do testing on air temp movements in the intake manifold a bunch of years ago.....
on gasoline engines the coolant lines through the throttle body and intake are for warming the air rather than cooling it. Since the fuel is injected into the air stream before entering the combustion chamber the air temp needs to be warm enough for proper atomization. It may have some cooling effect on turbocharged and supercharged engines as CT's data shows for the diesel.I am not to knowledgeable on the deisel but on my Toyota Supra turbo, it has coolant lines through the intake to keep tempatures down. You should not need more boost even with the extra tubing, there are rear mounted turbo kits for mustangs and vettes with little to no turbo lag. this is a good thread keep it going.
kill the HG's?... I would like to see what a holset hx40 would do on a deuce.
I must politly disagree. Maybe on a non turbo motor for emisions purposes you would want to warm the intake, But a turbo motor gets HOT. Maybe its just the way I drive Itjust my
