WIH3
- 0
- 0
- Green Bay, WI
Does anyone have torsion bar axles on their trailers. I have to order an axle tommorow.
That should come out very nice - I probably should have chosen the 3.5k axle, but I started down an 8 lug path and just stuck with it. Are you going to build a custom frame for a M101 box? I imagine that will cut down a lot of weight.I ordered a 3.5K axle today with brakes. I am not building that heavy of a frame with 6 bolt 16" rims, and 31" tires. I also ordered the same dimentions as you. 3500lbs should be just fine. I 'am expecting the trailer with box to come in @ 800 lbs. 2700lb payload is plenty.
hmmm....My buddy Daniel likes to leave his 16' trailer at my house when he goes on vacation, has relatives over or someone visiting and needs the driveway space. He brings his trailer to work swaps it onto my truck. I leave for home after work & call him 5min later and ask "WHAT IN THE WORLD IS GOING ON WITH YOUR BRAKES?" The trailer is locking up one least tire on the right side.
To make a long story short he gave each EZ-lube spindle two pumps with the grease gun. The grease pushed past inner bearing seals on two wheels, mixed with the brake dust creating big gooey mess. He bought the trailer new, and it came with 5200lb Dexter EZ-lube axles.
A case of brake cleaner to clean up the mess costs more than the EZ-lube option, not counting your time. If any of my wheel bearings starts to get loose, I pull the drum, clean, inspect and repack them.
Just my .02
HMFG
I hope to get the box and tailgate back on the chassis here shortly and will weigh it.Wow I think you did a great job lightening up. I was estimating the Box @ some where around 300-350lbs. Yes the frame is custom. My box is new. no paint or anything. I hope to be @ 200 with just the frame 3x2 box 14 gauge and the tounge is 3/16 . I should be @ your weight when done.
