Help with 'newer' Rockwell 5 ton axle info
four_by_ken
Allenton/MI
I dont have too much to go on yet, but I hope someone can help me out a little bit with some information and maybe a supplier of parts.
Model is RS15611NFSF
7.1:1 final ratio between the r&p and planataries
Both were manufactured in 1989 by Rockwell International.
Air brakes on both.
I was told they are a 5 ton rated axle, but I think they are more 7 ton.
Does anyone know anything about these, or can lead me in a direction to find more information? Main thing I am looking for is maintenance parts suppliers.
This is a picture of the actual axles.
I was told they came out of these type of vehicles
four_by_ken
Allenton/MI
Here is a little more info off the axles.... any help?
Rear
Model # rs15611nfsf
Ratio 710
Date 2968901
serial # and Plant NKA89061908
Part# A 3201 Z 7800
Front
Part# A 3201 J 7888x
Serial # KNH89167464
M813A1
OKC, Oklahoma
If those 5 ton axles have air brake cans on them that tells me that the axles are setup for use on the m939 5 ton series truck they all have full air brakes on them !!
four_by_ken
Allenton/MI
If those 5 ton axles have air brakecans on them that tells me that the axles are setup for use on the m939 5 ton series truck they all have full air brakes on them !!
I am far from an expert, but I think the 900 series uses a top loader axle... and does not use planatary ends.... and I think the 900 is a 6.44 or something ratio.
So, not quite what these are. They are air brake axles, thats for sure.
M813A1
OKC, Oklahoma
Are the axles front load like a commerical tractor trailer ?? If they are ,then those axles probablly are used on the M915, M916, M917 and M920 series truck. If you want to use them on a M39 series or M809 series 5 ton truck you will have to redo all the air system for the brakes to a M939 or M915, M916 series truck style of air brake system !!
DO YOU HAVE SOME PHOTOS OF THE AXLES ??
four_by_ken
Allenton/MI
Are the axles front load like a commerical tractor trailer ?? If they are ,then those axles probablly are used on the m915, m916, m917 and m920 series truck. If you want to use them on a m39 series or m809 series 5 ton truck you will have to redo all the air system for the brakes to a m939 or m915, m916 series truck style of air brake system !!
Yes, front load. Here they are...
But, I thought that the 900 series were not planatary axles?
298
Olean Ny
Bingo... did some more playing around.........
The first goes to a fire truck... the next 3 go to 2.5 ton LMTV's and the last goes to a MRAP
13317968
AXLE ASSEMBLY,AUTOMOTIVE,DRIVING
RS-23-180-NCDF85
MERITOR HEAVY VEHICL
13612516
RS-15611-NFSF-4-780
14639188
RS-15611-NFSF-07-780
15048170
RS15611NFSF8 780
15555450
AXLE,VEHICULAR,NONDRIVING
RS23160NFN216543
four_by_ken
Allenton/MI
Looks like they are 2.5 ton. No big deal there.
But, at least something is being found!
Now to find a supplier and hope parts are not out of this world!
