Josh
- 12
- 38
- Portland, Oregon
Does the truck get to 2600rpm in the other gears?
April 19th, 2010.
Scootertrs:
Could it be a possibility that your truck might have 5th gear still in it as an underdrive gear? The normal top end of an unconverted M35A2 with 5th as an underdrive should be in the 44-45-46 MPH region, if what all I've heard and read is correct. Besides, how many deuce firetrucks ever got off base?
There is an engine TM that goes through the entire engine troubleshooting/adjustment procedure step by step to get the no load RPM to the proper setting then to get the loaded RPM to the proper setting.
http://old.steelsoldiers.com/index.php?module=pagesetter&type=file&func=get&tid=1&fid=file&pid=57
Do you know if there is a similar TM for the NHC250?
Low range wouldn't limit the RPM's to 2000, and would limit the maximum speed in 5th gear to 28MPH... So that probably isn't the problem.I Know the problem ! You're in low range!!!!![]()
1236 gal of water... that is a lot of water... I hope I don't have to go to a turbo... I have spent enopugh money just getting the fire valves and pumps working... can't afford turbo right about now. As is, the gov info say that the turbo did not really increase the power, just cleaned up the smoke... don't really know... just parrotingScootertrs,
Does your truck have a turbo? if so is it working correctly? it might have an issue where it's not working correctly restricting airflow.
No turbo... air filter new
Does the pump work off a PTO from the main drive shaft like most regular firetrucks? or off a tranny PTO?
Fire pump works off transfer case pto (like a dump truck) Tranny pto is for the winch
How much water does your truck carry? We've never messed with a "real" deuce firetruck, all of ours are/were converted.
Water tank holds 500 gals. Foam tank holds 50.
Are you using a military air filter?
Air filter is a Baldwin replacement
Your truck may be governed because of the Fire Pump set-up.
Fire truck specs call for pressure/volumes at rpm's of up to 2250+ so I guess the governor is set for more than that?
Our M35A2 with "C" turbo & 1236-gallon water tank goes around 55-58mph.
Our 2nd M35A2 with "D" turbo & 500-gallon water tank goes around 58-62 mph. This truck came without a turbo and was a slow smoking dog before we added a turbo and re-timed the fuel pump.
OK... Road Test... after cleaning... 49mph - very little smokeYour governor shouldn't overshoot that much, so hopefully you are just seeing an instrumentation glitch as your tach needle swings past the mark, and returns.
Does your tach show a sustained 2600-2800 rpm at WOT, or does it do something else? [Note, running WOT unloaded is a standard part of the diagnostic testing for LDT engines.]
-Chuck
OBTW, if it seems to want to go past 2800rpm as you slowly head for WOT, don't let it!
Is the LDS built such that it can wind up to about 3K, but the LDT can't? The LDS troubleshooting manual says it can, if i remember correctly.OBTW, if it seems to want to go past 2800rpm as you slowly head for WOT, don't let it!
