HunterW
- 0
- 0
- Charlotte, NC
Thanks to the replies on my thread, I now have a new brake master in the truck. Installed the new style air brake pressure switch. Bled the master and all 6 brakes.
The brake lights will come on... and then stay on. I assume this means my air pack is malfunctioning?
I read another thread that mentioned the air pack should bleed off (pssshhhtt) after you release the brake pedal each time? Is this true? Mine has never done that.
The pedal will feel good at first pump, each after the pedal is VERY stiff and almost impossible to stop the truck. This would mean there is no longer air assist until it somehow bleeds itself off?
My brake lights are staying on because there is still air built up in the air pack assist system even after I release my foot off the brake pedal. It probably takes a good 5 minutes before the lights will go off after depressing the pedal and letting it sit.
Thanks for any help!
