1008Newbie
- 0
- 1
- Greenfield, IN
Hi Everyone,
I bought a M1008 two weeks ago, but the Gen 1 light does not come on. No charge on front battery. Back battery charge good. I have replaced the passenger side alternator (tested bad), but I didn't replace the drivers side because it was tested on the stand and they said it was good.
I just took out my instrument panel last night and removed 25 years of oxidation on all the light bulb sockets and plastic circuit sheet, and put in new bulbs, dialectric greased contacts, resistance readings on everything to make sure it was all good, and fixed my shift indicator as well.
Now I can see my speedo at night, have cabin lights, but still no Gen 1 light.
I have 12V to the Gen 1 bulb, and I have 12V to Alt #1 brown wire (exciter?)with key turned in ignition.
Any thoughts? Think I should go ahead and replace Alt #1 just to be sure? TM says to trace circuits, then replace Alternator, but Alt #1 tested good.
I do have an unknown Blue and pink/black wire hanging suspiciously next to the firewall on the drivers side (photo shown) I think the blue wire has 6 volts, and pink/black has 12V, not sure if that was intentional by previous owner after replacing relay, or if that could have something to do with charging problem.
The wiriing diagram isn't very clear to me. I think the ignition switch supplies power to Gen 1 light, then that power goes to brown lead on alternator, and not sure what happens after that, even after reading the posts.![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Thanks for any advice you may be able to offer.
Eric
Eric
