Stratoghost
- 0
- 0
- Belpre, Ohio
This is incorrect, while it looks the same a Ford starter relay is not ground actuated, it is 12V actuated. The stock CUCV system will not work with it because the Ford starter relay is grounded through the mount.You can also get away with a ford starter relay if you happen to have one laying around:
The picture I posted was my m1009 before I converted it to 12v and I know for certain that what is pictured is a generic ford starter relay. The truck started and ran just fine for some time as pictured.This is incorrect, while it looks the same a Ford starter relay is not ground actuated, it is 12V actuated. The stock CUCV system will not work with it because the Ford starter relay is grounded through the mount.
A Ford glow plug relay will work, as it is ground isolated with a positive and ground terminal.
I use a GPR for a 96 F350 when I ask for one at the parts store.
Later,
Joe
It is a Ford starter relay and it is most definitely grounded through the base to the firewall. I do know what they look like and how to test them. To an extent that I accidently shorted the relay pictured for several minutes with the glow plugs engaged and burned it up several months ago. I purchased and installed another Ford Starter relay from Autozone as the glowplugs were none the worse for wear.While it looks like a Ford starter relay, it is probably a Ford GPR. That looks exactly like the relay in my CUCVs that are 1996 F-350 GPRs, not starter relays. All Ford starter relays (that I have seen) are 12V activated with a second wire for ignition power during cranking, bypassing the ballast resistor.
Without ohming it out to find out if it's grounded through the mount I can't say for sure what it is, however, the stock CUCV glow plug system is ground controlled and if the relay is grounded to the mount it is impossible for the stock system to control it.
I don't want to get into an argument about what is/was on your truck because I'm not there to personally see/verify, but I want people to be aware that in my experience, Ford starter relays are not suitable to use as GPRs due to their internal electrical configuration.
Later,
Joe
This is where we run into issues. Once a truck is modified, all bets are off.That said, I do not use the gp controller and likely this is where our disagreement is founded. Mine has the switch update to manually cycle the plugs
