sandrider
- 0
- 0
- Bakersfield , Ca.
I just bought a 1961 M38A1 with the F-134 motor I want to add a oil filter to it ,but need some Pictures and info on where to install the oil lines and other info I might need to do it. Thanks ![Idea :idea: :idea:](https://www.steelsoldiers.com/images/smilies/icon_idea.gif)
Blue smoke, oil in exhaust, oil on #1 plug other 3 plugs had burnt oil. It is defiantly burning oil..I do have a bunch of the manuals I downloaded them when I first got it. As for the bubbles I went to go look and I popped the hood and noticed my oil pressure line to the oil filter was rubbing against the fan belt and was leaking oil. So my fun stopped there. I put a temp fix on it, I want to drive it around some more before I tear into it. When i bought this the guy told me it did not smoke at all but no way to show me because it did not run... Oh well I enjoy working on things. Some pics of the temp fix.first, Do you possess all necessary M38A1 manuals?
you can download concise collection of ref material and ord Manuals here:
Willys M Jeeps - Access Denied
give this a read Aaron, your quest will be answered.
G503.com Message Forums • View topic - CJ F134 in a M38A1
have you pulled the head off your motor yet? has it been milled, rather rebuilt already?
before you go spend money, do some investigation.
-white smoke ? coolant (water steam)
-blue smoke? oil
-black smoke? fuel (too rich)
look for bubbles in rad... during operating temp 160-180 deg. (head gasket.)
re-torque head bolts to spec
vacuum check ...
compression check. both wet and dry.
let us know.![]()
