BIG_RED
- 0
- 0
- Winnipeg, Manitoba
Hey guys,
My oil pan leaks quite a bit, so I'll be pulling it off to put on a new gasket this summer. What else should I do while I've got the oil out and the pan off? I've got some ideas, please let me know what you think about them (possible/worth it?) and maybe add some of your own ideas. Thanks.
1. Mechanical oil pressure gauge tapped into low oil pressure sensor (passenger side behind engine)
2. Main bearing web reinforcement kit - STUD GIRDLE KIT
3. Main bearing seals? mine don't leak yet..
4. Main bearings? can I replace them without pulling the crank?
5. Oil pump + pickup tube. Higher flowing?
