stock deuce rims
SETOYOTA
451
georgia
All m35s come with 9.00 x 20 tires. CCKW WWII 7.50 x 20 and the m135/211 came with 9.00 x 20s unless singled out. These are tires sizes
bratpackdad
Middle America
1968-71 the 9.00x20 were original issue. In later years the tires were changed to 11.00x20 tires, which are slightly heavier and wider than the 9.00x20 tires.
tm america
25
merrillville in
actually m35a1 and a2 came with 9.00 20s the m34 came with 11.00 20s. and the m35a3 came with 14.5 20s.any could have been switched to 11.00s or any other tire but thats what they came with orginally
m16ty
225
Dickson,TN
All M35A2 trucks came with 9.00X20 tires. Early and late.
all did except the m35a2 and the ones that had combat rims
I say again, All M35A2 trucks came with 9.00X20 tires with split ring wheels.
  • Like
Reactions: emr
emr
25
landing , new jersey
:deadhorse: just because i guess...:deadhorse:... i will add the rim will accept a 12 inch wide tire as it is stamped on most rims. max rim size 12 inch, that was not asked either, I do notice that alot of guys need to add,""" i think" or """"it is my opinion to there posts""...:-D.. they came with 900;20s unless singled like said earlier, never came from the factory with 1100 deuls. that happend in theater first. and never had combat rims. unless one thinks a rim that has been in combat is a combet rim. he he he
Flyingvan911
158
Kansas City, MO
I know it's alittle off topic but it seems like a good opportunity to ask. Can you put 11.0x20 tires on the deuce in place of the 9.00x20 without changing anything else? Is there much advantage to 11.0 vs 9.00?
