jesusgatos
- 28
- 38
- on the road - in CA right now
In the spirit of using my new LDS multifuel to it's full potential, I want to equip Mah Deuce with the ultimate fuel system. I'm talking about being able to pour just about anything flammable right into the fuel tank, knowing that it will be processed and filtered before it reaches the engine. The thing is, I'm actually going to be living/traveling in this M109 motorhome fulltime, so the fuel processing system has to be built into Mah Deuce.
When I started researching fuel filters and related components, the name Racor kept coming up. Everything I read seemed to indicate that they set the standard when it comes to fuel filtration. So I contacted them, and they've been really enthusiastic about this project. We're calling it 'an exercise in overkill'.
Although Racor has a TON of experience filtering ally types of fluids, it's not often that they're asked to do it all in one system. The problem is that a lot of components (filters, seals, etc.) are made to work with one type of fluid, and are not compatible with another. But I think we've came up with this list of components, that when properly configured, would seem to be able to filter just about any type of fuel.
I know that some of you have a lot of experience dealing with WMO, WVO, and filtering/processing a variety of other fuels/fluids - so I'd like to ask you guys to take a look at this list of components and tell me what you think. Have an idea about how we could improve on this? Please comment. I would appreciate the input.
Here's a basic rundown of the system as I'm currently envisioning it:
There will be a total of 100 gallons of fuel capacity, split evenly between two tanks: one 50 gallon tank in the stock location on the passenger's-side, and another stock 50 gallon fuel tank on the driver's-side (where the spare tire was). I'm planning on duplicating something like what's in the tractors with dual tanks. As of right now, I'm not planning on having a diesel-only tank. Instead, I'm relying on my ability to pre-heat the fuel. Radiant heating is being used throughout the vehicle, so it will be very easy for me to create a dedicated loop to heat the fuel tanks (I'm going to do something similar for the water tanks). I'll have two propane-fired tankless water-heaters onboard, and two multifuel-fired coolant heaters, which will serve as backups. There's also going to be a heat exchanger built into the engine's coolant system. Racor also makes this neat little coolant heater. But the propane heaters should work in spite of cold temperatures, right? So it seems kind of unnecessary to make room for a 'diesel-only' fuel tank. I guess that leaves me kinda hosed if the propane-fired water heaters went out for any reason though. Hmmmm. I'm obviously still thinking some of these things through. But that's why I'm posting.
Racor's Marine Turbine 1000 unit with a 30-micron filter will serve as the primary fuel filter. These things look amazing! It's a centrifuge, a filter, and a water-separator all built into one unit. This Turbine unit will also incorporate an optional 24V electric priming pump.
A second, identical, Marine Turbine 1000 unit with a 10-micron filter will serve as a secondary fuel filter. Racor is working on a full-flow electric pump that I would add to this Turbine unit whenever it becomes available. I just like the idea of having a backup (or two) when it comes to parts (like fuel pumps) that I might have a hard time replacing in the middle of nowhere.
Although the Turbine 1000 units are specifically designed to separate water from Diesel, Racor told me that I would need an additional water filter to separate the water from used motor oil, ATF, hydraulic fluid, and WVO. They recommended one of these filters in one of these filter housings. Only caveat is that this filter is not compatible with gasoline, so I'd have to make a bypass line that I would switch over to whenever I put gasoline through the tanks.
And then these filters would be equipped with 2-micron filters, and would serve as the final filters in the system.
This FPM-050 fuel polishing unit, along with a FPM-PTC-12 timer/controller, would circulate the fuel through the filters on a programmable timer, so I wouldn't have to worry as much about fuel going bad if/when Mah Deuce might be parked somewhere for a while. My inverter will automatically turn on a generator whenever my batteries discharge to a pre-set point, but ideally, I'd like to power that fuel polishing unit (and everything else onboard) with an array of solar panels on the roof of my M109 box.
What do you guys think? What would you add, or take away, or do differently? How would YOU design/build the ultimate fuel system for a deuce? The only thing to keep in mind, is that space is at a premium. This is a motorhome. I'm not trying to turn Mah Deuce into any type of dedicated fuel-truck.
