Napoleon_Tanerite
- 3
- 0
- Warner Robins GA
I'm looking for options for Air Conditioning for my M1009. Two promising ones seem to be the Vintage Air Mark IV under-dash kit, and the OD Iron CUCV kit. I've got a few special considerations for any AC I put in.
1. I have replaced the dash with a custom unit, so factory ducting most likely will not work. I will most likely be installing frog eyes or similar for AC vents as opposed to conventional square vents.
2. I have no intention of converting to 12v unless absolutely necessary. It's not that I'm particularly attached to the 24v system, but I'd rather not go through the additional hassle unless the hassle of installing an AC is greater.
With that said, aside from the two options I listed above, what else is out there? My number one concern above all is ease of install. I've pretty much resigned myself to spending ~$800-1000 to get this done, so as long as it's not too over that budget, cost isn't a major deciding factor. Obviously I'd like to save money if I can, but I'm already ok with spending the requisite money to get the job done.
