AZDeuce
- 38
- 28
- Tonopah, AZ
Gentlemen/Ladies:
I know some of you will cringe at this, but the glowplug system has been fried for the last 5+ years on my M1009. Being electronically challenged, I ran a hose from the air cleaner's inlet through the firewall and mounted it next to the ashtray where the lighter would go.
I give it a small wiff of starting fluid, and start her, if I give it a little too much you get a rattle noise, so I have learned to give it enough to start but not enough to rattle.
Been working great for years, but yesterday when I gave it a (LITTLE) wiff and started her, she rattled forever, and extremely loud, my first thought was wow I finally blew the engine, but when I reved the engne speed up, the rattleling would go away.
I had to drive it about 10 miles yesterday, and going down the road I couldn't really tell if it was making the noise, but when I hit a light/stop sign it definitely made the noise.
This morning I planned on changng the oil, so when I started it I gave it the usual small wiff of starting fluid but when it started it sounded like I gave it the whole can!
But yet if I put 3-400 RPMS on it it would quite down, ........BEATS ME!
I moved it on to my concrete pad, and watched all the belts, everything seemed normal, but the noise was so loud and distracting that I couldn' isolate the noise, so I shut her off and checked the alternators and power steering for looseness, but everything seemed ok.
After I changed the oil, and restarted it without ether as it was warmed up, it still sounded like I over fed it with ether. But I didn't use any.
I'm a bit perplexed as usually if something is screaming at you it will usually be self evident, but I can't find anything to pin this on.
I did see the current thread regarding "6.2 Detonation," and some of thoe issues sound like mine, except I believe his sound doesn't go away, it gets louder with more RPMS, mine gets quite with more RPMS.
I may have to pull the inpection pan and check the Torque Converter bolts, but I did that late last year and they were still tight, I'm pretty sure I lock tighted those weasels as I read on SS that they do come loose. Besides I doubt is would get quiter with more RPMS, it would probably get louder.
Anyway I'm stumped and at a loss, my current plan as it's my only daily driver is to drive it until what ever is making that noise gives up the ghost, and leaves me stranded somewhere.
I'd rather head it off at the pass, but I have no idea what/where the pass is at!
Thank in advance for any ideas.
