69dieselfreak
- 4
- 0
- rimrock az
any big truck junk yard should have them just tell them caterpillar fuel filter head with the primer and you should be good ![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
Hello Jimmy,After my stock filter base went bad I put a RACOR490 on mine. It has a 24 volt heating element,clear sight gauge with a drain at the bottom for watter, and best of all it has a priming botton at the top of the base along with an air bleed hole. I am useing it by it's self with a 10 micron filter. The only draw back is that RACORs are kind of expensive.
4770 1"-14 threaded filter bases for $21 but they're on back order: Wix 24770 & Napa 4770 Base - ON Backorder!!!: FleetFilter Secure Online StoreThanks all for the information. I have been running around town all day trying to find a generic filter head for doing this same project. I was planning on using 2 of them a primary and secondary. That might be a bit of overkill. Napa wanted $50 for the one the guy showed me. Years ago, we used to have high performance auto parts stores here in Las Vegas. I remember buying these heads for $20. I guess I am just getting old.
Hey CycleJay the ram-air pipe goes to a 4" hole in the radiator core support. For some reason they tac weld a piece of metal over it on the cucvs. Anyhow if you type " my cucv ram-air project " into the search function on this site it will take you to my mini write up about it and the pics. Includeing the one of the front where the air comes in at.Hello Jimmy,
Where does that ram air hose from the air cleaner lead out too?
a snorkel? or elsewhere? Do you have a photo of that too?
Thanks
CJ
Mine came with a 5 - 6 psi electric pump installed. Turn the key on and the pump starts immediately.My civilian pickup with the 6.5 has an electric pump that makes changing filters a breeze, that inspired me to install electric pumps on all my CUCV's I have owned.
Flip the switch, push the air out, flip it off. As a plus if your mechanical pump ever fails, the electric is right there and will work just fine. Any time I have had a mechanical pump fail I just removed it and ran just the electric.
