Trudge
- 0
- 0
- ballston spa NY 12020
does the five ton have full air brakes? or any thing else that would make it different then my duece and a half?
This is a state by state issue. Some states let you drive any size truck on a regular license as long as you are not for hire while other states may require a CDL due to the truck having tandem rear axles (regardless of weight). To add insult to injury other states have non-commercial A and B licenses. Your best bet would be to check with DMV in your own state. When you call ask for the regulation that covers the different classes. I have had DMV people tell me that I required a CDL but they did not take in to consideration that I was not for hire (that can make a difference). Don't just limit your calling to DMV. Check with the state DOT people (weigh scale officials) or State Troopers Commercial Law Enforcement division. The key thing is to get the reg number to read it yourself.does the five ton have full air brakes? or any thing else that would make it different then my duece and a half?
In Louisiana I am driving a 30K 5 ton truck on a regular Driver'd License. I had to take the truck to the State Police to have the Vin. verified and they didn't ask to see my DL or say anything about needing a CDL. I use my truck for personal use not for hire and it has Stenciled vin. as the tag.This is a state by state issue. Some states let you drive any size truck on a regular license as long as you are not for hire while other states may require a CDL due to the truck having tandem rear axles (regardless of weight). To add insult to injury other states have non-commercial A and B licenses. Your best bet would be to check with DMV in your own state. When you call ask for the regulation that covers the different classes. I have had DMV people tell me that I required a CDL but they did not take in to consideration that I was not for hire (that can make a difference). Don't just limit your calling to DMV. Check with the state DOT people (weigh scale officials) or State Troopers Commercial Law Enforcement division. The key thing is to get the reg number to read it yourself.
Ruppster
Class B is for a single truck (no trailer) or a large truck with a trailer no larger then a 10,000 pound rating. Class A (combination vehicle) is for large trucks with a trailer rated at over 10,000 pounds. If the trailer is rated for 10,000 pounds or less you only need a Class B. If a CDL is required.What type of CDL? A or B? and do you need the medical card?
That's cool. Virginia was the same way. If you were not for hire you could drive what ever size truck and trailer you wanted. Virginia followed the Federal guidelines for the state's laws about licensing as they kept the Federal exemption from needing a CDL if the truck was for personal use. I would carry a copy of the laws with you at all times though as all it takes is one Officer to not know the laws to ruin a good day.In Louisiana I am driving a 30K 5 ton truck on a regular Driver'd License. I had to take the truck to the State Police to have the Vin. verified and they didn't ask to see my DL or say anything about needing a CDL. I use my truck for personal use not for hire and it has Stenciled vin. as the tag.
If I remember correctly those issues were covered in:Ruppster, Do you have a link that has the Fed regulation you mentioned that exempts personal use trucks from the med card, annual inspection and CDL?
That's another gray area. Over on the ATHS forums someone posted a letter from some head honcho in the Federal highway office about this. The letter stated that cash prizes were okay to a certain point. Something about if you had to file taxes on the prize money or if the prize money was considered income and had to be declared as income on you taxes. If so you were in commerce. If not then you were okay. The problem is when I have talked to weigh scale officials they consider anything given to you for the purpose of hauling a vehicle as income, even if it's just a trophy. The problem is proving them wrong. That's why when I help my friends by hauling something for them I won't even let them pay for a gallon of fuel.whether or not one is in commerce is a tricky one. Ever haul an antique tractor to a pull where there is a prize? ever haul gravel for a buddy and he gave you a beer or something else of value? even if you don't place at the pulls technically you are in commerce as you may have received something for your troubles.
