AXLE GREASE ON MY REAR BRAKES m1009
pinwormfood
easton, pa
hi guys, i just replaced my front and rear brakes on my m1009. first problem i found was my right rear brake shoes were soaked with grease. the wheel cylinder was not leaking and i am pretty sure it's the axle seal leaking. I was wondering if someone has a part number for that bad boy. i looked in the parts book and couldn't find it. also, i noticed that my brakes stop me LESS than the ones i just replaced. is that normal. these are new and feel SOFTER than the old pads and shoes.....
any help fellas? thanks, pinwormfood
p3amea6
Jarvisburg NC
I just got that rear seal a few days ago for my m1008 at NAPA pn 28426 cost $ 9.22 I told him it was for a K30 and took old part so I could make sure it was right part. :grd:
Westech
CPL
6,104
211
cow farts, Wisconsin
well he has a blazer. The rear seal is the run of the mill 10 bolt 8.5 inch GM rear truck axle. The seals can be found at Autozone or where ever. There NOT a military part.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
These parts are still available through advanced auto parts/ napa / carquest
bumper to bumper auto parts.
or at your auto parts store pull the rear cover off you will half to remove the C clips to pull the axles check wheel bearing to also I would replace the pnion seal to this will stop any more problem try to bo this be for you finish the rear brake job or it will send grease all over your brakes and make them worth less.
