- 2,052
- 57
- 48
- Milford / Michigan
The starter drive in my deuce needed a starter drive since i got it. once and a while it would grind, so i had it rebuilt and everything looks good. My question is, how can i rotate the engine without the starter to inspect the ring gear? I know i could put it in gear and slowly crank the engine, but i dont want to start it. the nut on the crank dosnt look like i can get to it easily. it would be nice to pull the engine stop handle and crank it over with the ring gear tool like i have for a Small Block Chevy, but we all know we cant do that. My plan is i somehow turn the engine over real slow a couple degrees at a time because of the high compresssion and have my dad look through the starter hole to make sure everything is ok with the ring gear. so how do i do that? thanks!
