Freeze plug Woes
motormayhem
Tucson, AZ
Well my truck has been parked for the last month and I noticed a few drops of fluid on the axle and ground. After looking into it it looks like the drivers side freeze plug under the engine mount in leaking. Is this indicating a head gasket problem? What needs to be done to fix it? It runs about 195-205 when it is 105 outside and has had a radiator leak and failed heater hose in the last 6 months. Doesn't go through fluid and oil and coolant seem to be separated as far as I can tell.
eric_banks32
Granite City, Il
Freeze plugs corrode from sitting for long periods and improper coolant/water mixtures. If your positive its coming from a freeze plug, you can drain the coolant and put a new freeze plug in and down the road ya go.
motormayhem
Tucson, AZ
Well if it is any indication when I got the truck 2 years ago the coolant was dirt brown and it took 4 flushes and radiator clean out stuff to get the fluid to cleanup and the radiator was 50% blocked. I think that means someone wasn't keeping my freeze plugs rust free.
Well it looks like it is gonna need to be replaced. In the wiki it says a block heater should be a 41mm does that mean the freeze plugs are also 41mm.
Any words of wisdom to change the one above the motor mount without pulling the entire motor?
glcaines
2,802
Hiawassee, Georgia
The easiest thing to do is pop the old freeze plug out and take it to NAPA or another parts house and get them to match it.
