bottleworks
- 3
- 18
- Central NC
An Allison MT-647 freshly rebuild soon to behind the multi-fuel. Stay tuned.
It's closer to what isn't needed. It will need SAE #1 to #2 bell housing adapter, crankshaft spacer, flex plates, starter ring gear, oil to coolant cooler, piping for associated cooler, drive shafts, Allison shifter, TV valve linkage, 5 ton MF bell housing w/ true #1 SAE pattern, and a lot more.bottleworks, that is a great deal, what other parts you will need to make it work with a Deuce ?
let me know if you need help spec'ing the pump and motor.... To power the winch, it will be converted to full hydro. This trans has a PTO provision. There will be a hydro pump running off that PTO. That alone adds a lot of additional parts and cost. ....
How did this ever turn out?
