prairie
- 0
- 0
- Bloomfield, Nebraska
I got an '84 M1008 about a 1 1/2 months ago, and have put about 1200 miles on it.
Mechanically its in very good shape, as it only has 12,000 miles on it.
Body wise it has some rust in all the usual places and the typical forklift damage, including the driveshaft which has been repaired.
For the most part it runs and drives great despite a set of mismatched AT's.
Has the following problems and my repair plans:
death wobble-- new kingpin springs and bushings, matching set of balanced
tires, and replacement of a dented steering stabilizer.
Low Coolant light on permanently-- seems like common problem that I should be
able to troubleshoot
Chattering from behind dash near steering column-- another common malady that
shouldn't be to hard to troubleshoot
Miscellaneous wiring that needs to be tidied up--zip ties, loom and some wire
replacement as needed
It is my DD ranch/farm pickup and I already had a PowerLoc installed in the front.
To make it more capable I plan the following:
1" ORD body lift
1" Zero Rate/EZ Inch moving the axle 1" forward
Fender trimming as needed to fit and flex 36" Irocs on 17" wheels
Bolt in steering box brace
Possibly a disc brake conversion
Sylvania SilverStar Headlights
Headlight Relay Conversion
Receiver Hitch mounted below the bumper
When I get enough posts I'll load up some pics.
1" ORD body lift
