Amxhunter
- 0
- 0
- Mobile, Alabama
Yes i checked the threads ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Speedo spins OK by hand.
Take cable loose under truck - attach drill - don't work. Made sure core was as far in as possible and checked both directions.
Took cable loose at speedometer end. Both
ends turn.
Kinda makes me think the core end that goes into the speedo is bad ?????
How do you fix that without having to replace the whole cable ? If that's the problem.
ends turn.
