- 2,520
- 18
- 38
- San Angelo, Tx USA Planet Earth
OK, I've now emission tested two of my three CUCV's. The third one will get tested in a couple of weeks. I've got to replace it's exhaust system.
My vehicles ALL run 15/40 Royal Purple and an K&N air filter. And just before emissions testing they get an oil change. Which means I currently change my oil once a year in each vehicle. I also clean the air filter IF necessary - though that's generally every other year.
Other than that, the vehicles are completely stock. My vehicles ALWAYS pass the emissions tests the first time. All the numbers are from the dyno and are measured at the rear wheels. One run only. The vehicles were at operating temperature, as it's about a twenty minute freeway drive to the guy I go to for my diesel emission tests.
OK, first up is my 1985 M1009 Blazer with 66k miles on it with stock 6.2L, TH400, NP208 and gear ratio is 3.08. It showed 98 HP and 225 Ft/Lbs of torque
My M1028A2 dually with 18k miles on it with stock 6.2L, TH400 (recently rebuilt with upgrades and a tranny cooler added), NP205 and gear ratio is 4.56. As a side note, the dually also has Royal Purple in the transfer case and the axles. It showed 110 HP and 450 Ft/Lbs of torque.
I've got a 1984 M1009 that I will post the numbers on in the next couple of weeks after I get the exhaust system installed, the oil changed, the K&N air filter installed, the fuel filter base and all replaced, and I will then check all the belts, hoses, fluids (radiator, tranny, etc) and decide what can wait or what must be changed or fixed.or replaced. THEN it will be tested and registered.
So, you guys got any numbers on YOUR CUCV's? Not a competition, as these never were power house engines, but for their era, they actually produced a tick more HP and torque than the stock gas engine of the era.
