any1 near warner robins
  • Thread starter televisionman007
  • Start date
T
televisionman007
Guest
i need 2 dueces and a trailer picked up out of robins
Recovry4x4
LLM/Member 785
1,808
GA Mountains
In the event you get these off site, will you be bringing them back from the rally?
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Can't help with getting them off site but I have some resources you can use to get them home. Are you bringing extra drivers? I will have 2 tow bars with me, one set of towing lights and if it helps, you can drive my M1008 to the rally as it can easily be towed back via the towbar. Unfortunatly, I'm 3 hours south of Geneva.
Jimma
Hartwell, GA
Get in touch with SETOYOTA. If he cannot help and they are driveable let me know. I cannot tow them but for my gas expense I may be able to drive there this week and get them out for you.
T
televisionman007
Guest
im gonna have a tow bar when i get to the rally. im buying one from gimpyrobb. as far as drivers well i was gonna try and find some one at rally to drive one home as i will drive other home and rayzer will be with us in his duece. i could use the lights for sure jus incase. Do you need me to drive yr 1008 to the rally as im hitchin a ride with rayzer?
T
televisionman007
Guest
Hey there.if you could get them and put them at your house i would be more then happy to compaensate you.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
The Oh-8 doesn't need to go, I thought you were driving a burb. The advantage of the Oh-8 is you can drag it behind a deuce. FWIW I put CUCV tow barckets on the front of my burb so I can tow it with the deuce (should I need to). Worse comes to worse, you can drag one deuce with the other. It can be a pain but I've sure done it a bunch! As Jimma said, might sent a PM to Chuck (SETOYOTA), he's a top shelf guy and has helped many at Warner Robins.
T
televisionman007
Guest
sir i super appreciate the offer to drive yr m1008 that is too cool to say the least. I appreciate every one who chimed in and steered me towards chuck aka SETOYOTA, I cant wait to getem
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Chuck has always been there for the family needing stuff pulled from WR. Thanks again Mr Herbert!
