- 3,657
- 27
- 48
- Dallas, Texas
besides tires, which is at this point ![Beat the dead horse :deadhorse: :deadhorse:](https://www.steelsoldiers.com/images/smilies/beatdeadhorse.gif)
1.) I saw a chevy 454 attached to am M35 transmission, and that has certainly been done before. A member here had a 383 attached to one. That will take care of the speed. 83MPH at 4000RPM, 70@3370. It ought to have the torque to do it as well.
2.) M-35Tom here has offered a set of gears for the M35 transmission to increase the speed. Read this entire thread: http://www.steelsoldiers.com/deuce-modification-hot-rodding/14728-overdrive-gears-available-soon.html
This is well engineered, with, well.. a lot of engineering behind it, and that is what I would do, if I had an M35 and wanted more speed. It's what the old tyme hackers would have called "doing the right thing"
3. For mud, watch your axles, you can break them. The stock transmission is also barely rated for the 300 FT Lbs of the deuce engine.
I have a 5-ton and am not worried about the speed at this time, although I will be, and I could see several deuce-applicable options there too, such as:
'custom' differential gears,
custom transmission gears,
an aux trans behind the T-case (disengage the fronts),
losing the t-case and putting a compound trans. in.
None of this is cheap, but if there were a well engineered option, it would be worth a few $K in parts and labor to get the redline from 53MPH to 75. Even so, it would not be driven 75, (only crazy deuce drivers run redline) but at 65, the engine would be very happy at 1820RPM.
Whatever you do, post up with your project! If possible, keep appending to this thread even if a long time goes by between your updates.
