Winch Vent
Wildchild467
56
Milford / Michigan
I looked in the TMs and could not find a location for the vent on the front winch. Seems to me like each side of the winch would have one.
Also what holes do you check the oil from? i think i found one on one of the sides, but not the other
Wildchild467
56
Milford / Michigan
I developed a small leak on my winch on the PTO side. it has stopped dripping, but i do not know how much oil was in it. i added some to it just because i didnt know how to check it.... figure better looking at it than looking for it. so i am thinking i should start off with the simple things like check the vent to see if it is pluged, then check the oil level.... wherever the plugs are to check the oil levels
Wildchild467
56
Milford / Michigan
sounds good! good to change the oil anyway. maybe ill measure how much oil i get out of both sides, then ill know if it was over full.
What about the vent? it does not have one then? seems like it should.
m16ty
211
Dickson,TN
If you've got a leak try some "John Deere corn head grease". It's alot thicker than 90wt and lubes the winch fine but doesn't leak as bad. Do a search for "corn head grease" and you'll find several threads about it. I run it in my winch.
