ptg530C
- 0
- 0
- almont, mi.
Transmission jack and no friend. 4 hours.
Awesome!Transmission jack and no friend. 4 hours.
My engine hoist just reaches in far enough. I used a similar method for an alignment tool, I used a standard deep well socket and a deep well impact socket (with some "shim tape"). It worked perfect.Great wite up. I have some insight too add to this.
I've done mine a few times. I use 2 2X4's one one each side of the center post thought the windshieds,and the rear of the cab. For added safty I tie the 2 together around the center post so they can not move. I use a pipe or crow bar across the 2x4's to hang the chain hoist from. This way you can move the chain hoist back and forth. I tried a eng hoist but the one I have does not reach thought the door far eought to do the job. So keep this in mine if you go to buy one.
If you are doing this for a clutch you can use a socket and extension and some tape. too make a clutch alinment tool.
