m35a3 tire fit
Recovry4x4
LLM/Member 785
1,814
GA Mountains
Can probably get them on the A3 rims but you won't be able to get them on the A3 truck without extennsive mods.
flyxpl
9
Chatham IL
I also believe you need to research the bead style that the A3 rims are designed for . The A3 tires have a different bead then the tire you want to use . I know guys are doing it , but then some guys say not to .
KsM715
142
St George Ks
Is your truck bobbed? If your running tandems in the back 16's will not fit without separating the rears. Extensive mods like recovery4x4 mentioned.
