airmech3839
- 5
- 18
- Augusta, GA
![Doh! :doh: :doh:](https://www.steelsoldiers.com/images/smilies/smiley_doh.gif)
![Funny Post! :funny: :funny:](https://www.steelsoldiers.com/images/smilies/funnypost.gif)
Good point. It actually made a pretty good spray rig. I could have driven up and down the camping/vendor area a couple of times and saved Carnac the money he spent on ant poison.You could have used the fuel on the red ants that popped up under the tent at the rally.
sw
Ranger - I have this exact same problem. When I pulled the delivery screw out I removed the screw and a spring, but I did not see a valve or any other component in there. After reinstalling the spring and screw, the leak was much worse (shooting jets of fuel out at idle...I tried to loosen and re-tighten the screw, but it leaked just as bad, or worse. So I switched it with the one in our 2nd truck, that we don't use, and it solved the problem. I did note that you can't change the valve, just the screw...
The valve is in there, it just doesn't fall out with the spring. As Floridianson said, it is matched to the HH, and you cannot change it. I didn't remove it, just pushed the spring back inside, and put the new "screw" in.Ranger - I have this exact same problem. When I pulled the delivery screw out I removed the screw and a spring, but I did not see a valve or any other component in there. After reinstalling the spring and screw, the leak was much worse (shooting jets of fuel out at idle.)
Did you pull a valve or checkball or anything else out with the screw and spring?
I don't have a 2nd vehicle to pilfer parts from, do the usual suspects carry a replacement? I really don't want to replace the entire HH over this.
Cheers mate. I am glad to hear this is a fairly common problem, and it sounds like it's an easy fix. I have to move in a couple of weeks and can't afford for my truck to be out of commission.The valve is in there, it just doesn't fall out with the spring. As Floridianson said, it is matched to the HH, and you cannot change it. I didn't remove it, just pushed the spring back inside, and put the new "screw" in.
Gimpyrobb told me this is a fairly common problem, and he knows of other people that have had to change the screw because of cracks. He is sending me a replacement for our second truck, and I would assume there are plenty of other spares floating around out there.
You might post a wanted ad in the classifieds, or put in a call to some of the supply companies. OD Iron, Memphis, C&C, etc.
No, I couldn't tell by looking at it. In fact, I still wasn't sure until I put the defective screw into the second truck. When I started it, it leaked.One last question: when you removed your screw and inspected it, was it apparent there was something wrong? With mine I don't think I could have told a difference between mine and a brand new one, i.e. no obvious signs of defect.
It looks like a lot, for such a small leak, but don't underestimate the fuel pressure in the HH.In the pic I have circled the puff of fuel vapor. I took this before I had removed and reinstalled the screw. Seems to me like a lot of fuel on the HH for just that one leak, but I can't imagine having leaks in multiple places all spring up at exactly the same time.
A'ight - thats good to hear. I was concerned I was losing fuel from somewhere else as well and was going to need to replace/rebuild the HH. I will try the screw and see where that gets me. Presuming I can find one.It looks like a lot, for such a small leak, but don't underestimate the fuel pressure in the HH.
Ours did not leak a drop, at idle, but when revved it sprayed a lot of fuel. I used degreaser and a pressure washer on the undercarriage to help find the leak. I drove it one mile down the road and back, and the entire underside of the truck was soaked. It was on the outside, and even coming into the cab through gaps around the floor pan bolts.
It was moving a lot of fuel, under throttle.
