wsucougarx
- 63
- 48
- Washington State
Did a couple little things to the truck. I haven't had a whole lot of extra time to work on her. Plus the weather has been other than favorable over the last 3 weeks or so. I was able to accomplish something that has been on the list since day one. That was to mount my two jerry can mounts to the mudflaps. It took a little extra work compared to my M35A2 mudflaps. The M109A3 mudflaps a a bit shorter and the upper clearance is lower with the crossmembers. I had to fabricate some brackets using stock "L" shaped steel for mounting. Really, all the weight is being supported by the top two bolts on the jerry can mount. I also wanted to mount them at an angle to allow for drainage . I also installed some of those footman loops and added a couple ALICE straps to secure the jerry cans during off roading. I had some large angle brackets used for somekind of battery relocation kit. I figured I would untilize the dead space just under the van between the rear axle and the pintle. Not exactly sure what I'm going to mount there but I'm sure I'll think of something...tow chain, tire chains. etc. Whatever it is, it'll be something non-critical as it may be damaged when ascending up steep grades. I'm thinking about using an M813 tool box. I'll need to take some measurements to make sure that hinged top lid will at least goto a 90 degree opening to get things in/out OK. I replaced the old aging and cloudy rear tail light assy. I replaced the plastic housing with a set of aluminum ones and brand new lenses.
I also picked up a QEAM (Quick Erecting Antenna Mast) designated AB-1386/G. It is around 8 ft tall and there are several sections to it (about 40 ft extended). I need to track down the manual hand crank and mounting base plate for her. She was designated to be mounted on the HMMWV or tracked vehicle. I also secured a tow bar holder (HEMTT style), couple NOS MX-6707 antenna bases, 30ft slave cable, plastic battery box for the HAM radios, and a few little things here and there.
Info on the AB-1386/u mast:
Designed for manual operation, Will-Burt's Quick Erecting Antenna Mast (QEAM) elevates light payloads for ground-mounted, vehicle and shelter deployment.
The QEAM TM 10 is recognized as the AB-1386/U for the U.S. Army CECOM.
Features:
Easy manual crank up
No power supply needed
Automatic locking collars
Locks at any height desired
Patented latch mechanism
Manual mechanical drive
Reliable deployment without power
Standard ground mounting kits with guylines and transport bag included
Portable guyed field mast
Tubes made of high-stregnth 6061-T6 aluminum tubes
Meets MIL-STD-810F environmental standards for operations in extreme conditions
Model - TM 10
Nested Height - 8ft/2.4m
Extended Height - 32.8ft/10m
Guying - 2 level/3 way
Number of Sections - 5
Weight (mast only) - 42lb/19kg
Weight (accessory kit) - 57lb/26kg
Payload capacity - 15lb/7kg
Max. sail area - 6sqft/0.6msq CD=1.5
Ice load - 0.5in/12mm
Max. erection wind * - 25mph/40kph
Operational wind - 60mph/97kmph
Survival wind - 80mph/128kmph
Surface mounting - ±15°slope
Deployment time - 2 persons, 7.5 min
Drive system - Screw drive
Finish - Mil-F-10472, AG, CARC
Project Completed:
Jerry Can holders on mudflaps
Tool/chain box supporting arms on rear
Replaced rear tail light assy w/metal housing ones w/NOS lenses.
Replaced front axle vent valve
Features:
Model - TM 10
Project Completed:
