Towman2277
- 0
- 0
- Saraland, Alabama
Last night I was called out on an off-road recovery, where a truck went about 200' into the woods. I decided to take my bobber, as it had a very muddy and tore up access road to the scene of where the truck was borken down, and stuck.
I found some hard ground, with some loose gravel on top, and proceeded to send out winch cable straight into the woods from my chosen spot. I had a worker who i was on the phone with, giving me details of the truck and cable, since I was in the truck operating the winch.
I sent him with a snatch block to hook to a tree, due to us having to do a right angle pull to get the truck out of the hole it was in. Very simple pull.
I winched some after the hookup, and nothing really budged, just pulled my truck forward.
I was then asked to just "back up" as the winch speed wasn't helping pull him over as he was trying to back out of his stuck hole.
I locked my truck in 4 wheel drive then backed up, and dug in a little. I told everyone to watch their hands, I'll try harder! So I eased up, then backed up (in low range) with a good hard pull. Nothing. No budging.
I was digging in deeper, so I knew i had to pull very hard, or give up and get out a dozer. I got down on the truck backing up, spinning all four HARD, then "snap" from the front end. I pulled the truck forward out of the ruts, and jumped out with the truck in nuetral, with the front end locked in. I reached under, the front shaft would not spin (locked in with driveline). When i unlocked my air-shift front end, it spun FREELY!!!!!!! YIKES!!!!
To make a long story a little shorter, my "helper" didn't even use the snatch block, he simply wrapped the cable around a huge pine, and as I pulled in reverse, it dug in very deep and snagged very good, killing my right angle pulling motion!!!!!
SO, today i'm pulling my front end, and swapping out a chunk!!!!!!
