Anyone have any bad hoses or know the fittings and lengths of each hose?
5,134
I want to see about stainless steel brake hosing for each hose on a deuce. Does anyone know the fitting size/style and hose length for everything? Or does anyone have junk hoses laying around I could use to model off of?
WillWagner
3,151
Monrovia, Ca.
Like the coolant hoses? I changed out the F/P oil supply lines to braided stainless.
5,134
OOPS! I totally zoned out on that. Brake lines is what I was looking at.
Edited to correct the OP now.
WillWagner
3,151
Monrovia, Ca.
Measure the ones you want to replace and go down to your local hose supply. They'll make them and test them.
5,134
Measuring hose length is the easy part. It's knowing the fitting flange style and size that is the hard part. I'm not going to remove every hose at one time from my truck to do this. That's why I was asking if someone had some I could borrow or knew the fitting size/styles for each end.
WillWagner
3,151
Monrovia, Ca.
:idea: Ahh, the light comes on! I think I have some NOS ones in the garage. Tonite i'll go look see and let you know.
The line wasn't much but I about had a coronary when I saw the price of the fittings, and I get them at dealer prices.
Kohburn
SOMD
yeah those anodized oil fittings are $$, but they are really nice also. I go for the summit racing brand black anodized fittings rather than the common red and blue.
5,134
Have you had a chance to look? :-D
doghead
4 Star General /Moderator
1,191
Will is on vacation for a few days.
Capt.Marion
15
Atlanta, GA
I'd highly recommend Royal Brass and Hose... Royal Brass and Hose Sales and Distribution Branch Locations.
I had a burst brake hose, so I pulled all of the rest of the hoses and one buggered up brake line and had them make me all new ones instead of chancing whatever the dealers are selling. Another member here has had custom steel-braided brake hoses made for his Gama Goat to go between the tractor and carrier and was very satisfied as well.
5,134
I was planning on seeing what I could build a set for from summitracing. But if not, I was going to get southeastern hose to make me some. (Local shop to me, they've done a lot of work for all of us here) I just need examples of all the lines to build them from. I don't want to pull mine apart for the fittings/lengths though.
