Clear, 7/8" UNF is 14 tpi. Needs to be -18.i tried a 7/8 fine thread bolt in the pan it started a ways and then stoped......
sounds like a hyd. fitting thread size, these are different then UNFClear, 7/8" UNF is 14 tpi. Needs to be -18.
G.
Old thread, I know, but is the dimension and thread pitch the same for both the front-most and rear-most oil drain plugs?7/8"-18
g.
