ccequipment
- 6
- 18
- Unionville,IN
A little play is normal thats what the pilot bushing is for.
I also noticed (not sure if it's related) that many of the holes where the tranny bolts to the adapter plate seem to have coils in them. Maybe someone tried to draw the tranny on with the bolts and stripped them out?
Maybe the tranny came loose via the stripped bolt holes and wore your pilot bushing out. This would also explain the copious amounts of "puck dust".
Dirt
not that it makes you feel any better but, thats what folks charge around here as well.Tks for the counsel guys. I dropped the flywheel off at the machine shop last night. $60 to get it resurfaced. I think I threw up a little in my mouth when he told me......
Maybe my terminology is wrong? I would think that if the truck was in gear, but I had pressed the clutch to the floor the output shaft should spin freely?It shouldn't. If your in gear and the clutch is engaged, you should be spinning the motor.
