- 7,406
- 2,498
- Interlachen Fl.
Went to return the 816 to day and was waliking away when I heard a air leak. Great trace it down and it is the air shift / sprag on the trans. It blew out the gasket that is on the top cover. The bolts were a little loose and this is why I think it let loose. So this is a simple 10 min. Job that everyone should check by just take off battery cover. I used a 3/8 drive long extension flex head 7/16. I will from now on check all my trucks that have this system. I found this gasket stuff at Advanced and made new gasket. Very easy just make it all one peice instead of two peices. I guessing most people know or it has been posted before so the only bolts to remove the peice is top left bottom right on each cylinder.
