Installing a Tachometer!
150
12
BNE, Oz
lots of aftermarket speedo setups designed to feed to rally computers, basically a prox counter setup, any rotating shaft (preferably keyed) could be set up... question is more how/where would you mount the readout....
Spock
Gamagoat1
Kiowa, Colorado
If you'll look at the 353 above the bell housing on the right side, slightly left and above the fuel pump, there is a little port covered by a two bolt cover. Guess what, that's a tach port.
dmetalmiki
2,027
London England
just got my forehead off the floor
Thank YOU than you thank you! tomorrow I WILL be makng / fitting / attempting to fit a rev counter to my goat. would be real nice if i can use an M series rev counter. dont know why "they" did not fit one in the first place. but I shall certainly be doing that as my vry next project.
kubotaman
124
RI/MI
Has anyone actually added a tach to a Goat? Could be mounted on top of the dash it seems.
