- 2,054
- 59
- 48
- Milford / Michigan
I wouldn't use steel - it is asking for trouble. Sometimes it's difficult to tell how much strain there is even when being careful. I have also heard of some of the aluminum shear pins being made of the incorrect alloy, which is softer. Perhaps this is why some aluminum pins are shearing. I've used my winch many times , winching my Deuce, other trucks, tractors and trees and I have never sheared a pin. Although I do have a 10-ton snatch block, i normally don't use it because I'm lazy and it's heavy. My pin is definitely aluminum and is the original pin installed when I picked the truck up from GL.
Good Point. Im the same way with my winch. i need to get some aluminum pins. seems like any grade of alminum will be better than a grade 2 bolt. I should buy another 10 ton snatch block anyway though.... just because.
